Advantech ARK-3533-1 comparison
RSI iPC400 vs Advantech ARK-3533-1
Compare configured prices and practical differences in CPU, memory, storage, expansion, I/O, power, and operating-system options. The example selects the same i5-13500TE, 16 GB memory, 480 GB SATA SSD, and Windows 11 IoT Enterprise 2024 LTSC on each system.
iPC400 starting configuration
Product details
Design details at a glance
Review serviceability, installation, and maintenance details for the products in this comparison.
Start with a matched configuration
The default example selects the same i5-13500TE, 16 GB memory, 480 GB 2.5-inch SATA storage, and Windows 11 IoT Enterprise 2024 LTSC, with no expansion kit selected.
Check the expansion interface
The iPC402 option adds two PCIe Gen5 slots. The ARK optional kit adds two legacy PCI slots, so confirm the card interface your system needs.
Compare the I/O and power needs
The ARK lists four Ethernet ports and eight COM ports, plus 9–36 VDC input. The RSI iPC400 series emphasizes front-facing I/O and ten USB ports.
Transparent comparison
Choose the configuration you actually need
Compare the selected configurations against the closest publicly available ARK-3533-1 match, using stated assumptions for transparency.
Primary product
RSI iPC400 / iPC402
Closest public match
Configured public price
RSI iPC400 / iPC402 price breakdown Show details Hide details
Public configurator values reviewed October 14, 2026. Prices and adders use the published configurations available on the review date. Verify current pricing before purchase.
ARK-3533-1 price breakdown Show details Hide details
U.S. prices in USD, checked October 14, 2026, for the configurations shown. Taxes, shipping, duties, and optional warranty extensions are excluded. Configurations are approximate matches; key differences appear below. Other component choices may cost less. Prices and availability can change.
Selected dropdown comparison
Your selections, compared side by side
Each row reflects the dropdown choices above and shows the primary product configuration next to the closest ARK-3533-1 equivalent.
CPU
Primary product
ARK-3533-1
Memory
Primary product
ARK-3533-1
Storage
Primary product
ARK-3533-1
PCI Expansion
Primary product
ARK-3533-1
Operating System
Primary product
ARK-3533-1
PassMark CPU Mark is a multithreaded processor benchmark; higher scores indicate more throughput in PassMark's test suite. Real-world performance varies by system and workload. Source: PassMark CPU Benchmarks, scores checked October 9, 2026.
Differentiators
Product differentiators
Review warranty coverage, CPU options, expansion, and product features.
Warranty coverage
Warranty coverage
RSI includes 3-year coverage. Compare the cost of 3-year coverage from the other manufacturer.
RSI iPC400/402
3-year limited warranty; memory and storage excluded
2-year system warranty; paid 3-year extension varies by configuration
CPU comparison
CPU generations and options
Compare the CPU generations and options available for each system.
RSI iPC400/402
12th-, 13th-, and 14th-Gen Intel Core CPU options.
Celeron G6900E and 12th/13th-Gen Intel Core i3, i5, i7, and i9 options.
Expansion options
PCIe Gen5 or optional legacy PCI
RSI iPC400 / iPC402
Two PCIe Gen5 slots.
Optional two-slot legacy PCI kit. PCI and PCIe are different interfaces.
Performance without compromise
Supports 65W CPUs via auxiliary cooling
RSI iPC400 / iPC402
Supports 65W-class CPU configurations with the required external fan kit.
Supports 12th-, 13th-, and 14th-Gen Intel Core processors up to 35W TDP.
Connectivity
Select for the ports your machine needs
RSI iPC400 / iPC402
Three LAN, four serial, ten USB, HDMI, and DisplayPort.
Four LAN, eight COM, eight USB, and two HDMI outputs.
Industrial protocol support
Machine networks and fieldbus protocols
RSI iPC400 / iPC402
EtherCAT compatible. OPC UA, Modbus, and PROFINET integrate through software.
The reviewed ARK-3533-1 manual does not list EtherCAT, OPC UA, Modbus, or PROFINET support.
Storage access
Front-access SSD tray vs. internal drive bays
RSI iPC400 / iPC402
A tool-free, front-access SSD tray makes drive replacement easier.
Drive installation or replacement requires removing the bottom cover and drive bracket.
