OnLogic HX500 alternative
Before you buy OnLogic, compare iPC400
If you are evaluating the OnLogic HX500, also known as the Helix 500, compare it against an industrial PC built for serviceability, price transparency, and long-life platform availability.
Starting at
Product details
Design details at a glance
Review serviceability, installation, and maintenance details for the products in this comparison.
Front-facing I/O
Access, wire, and troubleshoot directly from the cabinet front.
Tool-free SSD tray
Swap storage in seconds without opening the chassis.
Vertical mounting
Clean, space-efficient fit for standard control cabinets.
Transparent comparison
Choose the configuration you actually need
Compare the selected configurations against the closest publicly available HX500 match, using stated assumptions for transparency.
Primary product
RSI iPC400
Closest public match
OnLogic HX500
Configured public price
RSI iPC400 price breakdown Show details Hide details
Public configurator values reviewed October 14, 2026. Prices and adders use the published configurations available on the review date. Verify current pricing before purchase.
HX500 price breakdown Show details Hide details
U.S. prices in USD, checked October 14, 2026, for the configurations shown. Taxes, shipping, duties, and optional warranty extensions are excluded. Configurations are approximate matches; key differences appear below. Other component choices may cost less. Prices and availability can change.
Selected dropdown comparison
Your selections, compared side by side
Each row reflects the dropdown choices above and shows the primary product configuration next to the closest HX500 equivalent.
CPU
Primary product
HX500
Memory
Primary product
HX500
Storage
Primary product
HX500
PCI Expansion
Primary product
HX500
Operating System
Primary product
HX500
PassMark CPU Mark is a multithreaded processor benchmark; higher scores indicate more throughput in PassMark's test suite. Real-world performance varies by system and workload. Source: PassMark CPU Benchmarks, scores checked October 8, 2026.
Differentiators
Product differentiators
Review warranty coverage, CPU options, expansion, and product features.
Warranty coverage
Warranty coverage
RSI includes 3-year coverage. Compare the cost of 3-year coverage from the other manufacturer.
RSI iPC400/402
3-year limited warranty; memory and storage excluded
OnLogic HX500
2-year limited warranty
CPU comparison
CPU generations and options
Compare the CPU generations and options available for each system.
RSI iPC400/402
12th-, 13th-, and 14th-Gen Intel Core CPU options.
OnLogic HX500
10th-Gen Intel Core processors.
Functional by design
Hidden & concealed USB bay
RSI iPC400
A concealed internal USB bay secures software keys and service dongles.
OnLogic HX500
No concealed USB bay for software keys or service dongles.
Performance without compromise
Supports 65W CPUs via auxiliary cooling
RSI iPC400
Supports 65W-class CPU configurations with the required external fan kit.
OnLogic HX500
Supports 10th Gen S-series CPUs up to 35W TDP.
Built for scalability
PCIe Gen5 expansion
RSI iPC400
iPC402: two PCIe Gen5 slots.
OnLogic HX500
PCIe x16 motherboard connector; chassis riser not listed.
Industrial protocol support
Machine networks and fieldbus protocols
RSI iPC400
EtherCAT compatible. OPC UA, Modbus, and PROFINET integrate through software.
OnLogic HX500
The reviewed HX500 documentation does not list EtherCAT, OPC UA, Modbus, or PROFINET support.
